R16TS cylinder head thickness ?
Results 1 to 8 of 8
Like Tree2Likes
  • 1 Post By R8philSA
  • 1 Post By Berridale
Thread: R16TS cylinder head thickness ?
    Feb 2012
    Vista SA
    986
    Default R16TS cylinder head thickness ?
    I'm trying to find out what a standard R16TS cylinder head thickness is. I have a 807-03 engine in the Barn Find.
    Can't seem to find this out anywhere including my 'Intereurope Repair Manual 141'
    Any help would be greatly appreciated.
    Thanks guys
    Phil
    Simon's Avatar
    6,203
    Nominal height 93.5mm.
    Minimum repair height 93mm.
    1963 Renault R4 Van
    1964 Renault R4
    1967 Volkswagen 1300 Deluxe
    1969 Renault 8 Gordini 1300
    Oct 2014
    Windsor 2756 NSW Australia
    697
    Yep, they're the numbers. I just went through that last week on a head I found to be 91.7
    Trying to figure if I can use it somehow..
    Feb 2012
    Vista SA
    986
    Quote Originally Posted by Bustamif View Post
    I guess 2 head gaskets is out of the question ! How about thin layer of plasterseen on the piston face and do a test assembly. Soon tell you if anything will hit the valves or not.
    Phil
    Berridale likes this.
    Feb 2012
    Vista SA
    986
    Thanks Simon. Greatly appreciated, Phil
    Jerangle
    822
    Might be worth asking someone who has worked over the 16 TS engine to find out how far they have taken down a head.
    Renault min head height could be conservative?
    Sunroof likes this.
    1000+ Posts driven's Avatar
    Apr 2005
    1,626
    You could try seeing what the clearances are between valves and pistons.
    Set liner protrusion to minimum
    Put some Plastigauge on the piston where valves would overlap
    Cam is probably worn so lift will be less anyway
    Refit head and gasket, carefully rotate.
    Work out clearance from Plastigauge
    Increase protrusion of cylinder liners to max if required.
    Last choice grind a bit from piston crown :-(
    Plastigauge - Plastic Precision Clearance Gauges
    Oct 2014
    697
    Thanks for the additional comments but lets not get ahead of ourselves, I don't want to hijack the thread. It's just a bare head at the moment. I think it came off a TS motor running Alfa Liners and some flat top pistons with a big cam and valve relief pockets. I have to decide if I use it on the Floride project or just keep it in the spares pile. From memory it was a 1970's race motor and the head was shaved past the normal repair limit to get some compression with the flat top pistons.
