Renault Scenic, 2001 slow to start sometimes?
Results 1 to 9 of 9
Like Tree3Likes
  • 1 Post By COL
  • 1 Post By COL
  • 1 Post By Berridale
Thread: Renault Scenic, 2001 slow to start sometimes?
    Jerangle
    822
    Default Renault Scenic, 2001 slow to start sometimes?
    It starts perfectly sometimes just turn the key, other times you have to turn the ignition off and re-start a couple times but it does start.
    The car runs fine and once going there is no abnormal running.
    What is causing this and how do i fix?
    8,496
    We probably need more info….Is the starter labouring or is it possibly fuel starvation???
    Jo
    COL
    COL is offline
    A110 COL's Avatar
    Van Diemen's Land
    4,478
    I would say clean the TDC sensor and see how you go.
    Regards Col
    2002 Renault Laguna V6
    1973 Alpine A110
    Jerangle
    822
    TDC sensor could be it.
    What other cars have the same sensor, any Peugeot cars?
    Starter perfect, not changed fuel filter which I should do.
    Wonder if the key battery can cause this?
    COL
    COL is offline
    A110 COL's Avatar
    Van Diemen's Land
    4,478
    Quote Originally Posted by Berridale View Post
    The battery in the key will not cause this problem. The battery is only there to operate the keyless entry function.
    Berridale likes this.
    Regards Col
    1973 Alpine A110
    Jerangle
    822
    Col,
    no relationship between transponder battery and the sensor ring around the ignition switch?
    COL
    COL is offline
    A110 COL's Avatar
    Van Diemen's Land
    4,478
    Col,
    There is a RFID chip in the key that does the security bit.The sensor ring detects the chip and if valid will allow the engine to start.
    The chip gets its power from the sensor ring, the RFID chip is not powered by the battery in the key.
    Regards Col
    1973 Alpine A110
    Brisbane/Australia
    2,226
    First option, TDC sensor dirty as mentioned above.
    Second option, air leak from throttle-body seal.
    The rubber seal goes hard with age and doesn't make a perfect seal letting in air.
    The mixture is very lean and as the seal is after the MAP sensor the EMC doesn't know.
    As the throttle-body heats up it expands slightly sealing it off again so is usually fine when the motor is warm.
    After that, then one can look at the myriad of sensors AMP, Temperature, Oxygen, etc.
    Jerangle
    822
    I took the TDC sensor out and found it with debris on the sensor head.
    This was pleasing.
    After cleaning the head the car starts without issue.
    JohnW likes this.
