Engine and Gearbox for R12?
Results 1 to 25 of 28
Like Tree7Likes
Thread: Engine and Gearbox for R12?
    Administrator
    mistareno's Avatar
    Nov 2002
    4,926
    Default Engine and Gearbox for R12?
    I saw this R18 on ebay with a 1600 crossflow and 5 speed box. Might make a good donor vehicle for a R12G replica?
    Renault 16 TS R18WAGON in NSW | eBay
    Brisbane/Australia
    2,227
    Are there any R18's still on the road in Australia?
    The last R18 I saw was over 10 year's ago and that was in a wrecker's yard.
    Haven't seen one on the road or drivable since the 80's.
    This wouldn't be a bad buy for someone near by, I'm too far away.
    Feb 2001
    Romsey, Victoria, Australia
    4,923
    Someone please don't let another 17 motor get crushed. We're running out of them.
    Shoji and Berridale like this.
    David Cavanagh
    03 9338 8191 or 03 93354008
    34 KING St
    AIRPORT WEST
    VIC 3042
    frenchconnect@bigpond.com
    Jerangle
    822
    Spare block "o ring"type.
    Are the Gordini engines paper or "o ring" ?
    Both are 1565cc.
    Simon's Avatar
    6,203
    Quote Originally Posted by Berridale View Post
    12G and 17G use paper (Excelnyl) liner seals.
    1963 Renault R4 Van
    1964 Renault R4
    1967 Volkswagen 1300 Deluxe
    1969 Renault 8 Gordini 1300
    1000+ Posts bowie's Avatar
    Aug 2002
    Sydney, Concord City, Sir.
    3,614
    Oh that has a bell housing / gearbox I want. Bega..
    Hmmmm
    Shoji likes this.
    Boonah Qld
    2,681
    Quote Originally Posted by David Cavanagh View Post
    Says it is an R16 engine. With a 17 timing cover with pulley. Hence bits are from a 17 TL. No mention of a Gordini that I could see.
    R16 engines aren't scarce Melc has 251 of them.
    Dec 2010
    Blackburn Victoria
    505
    Bowie, it's only 6.5 hours driving to Bega from Melb.
    JohnnyAfrica12G likes this.
    Feb 2001
    4,923
    My guess is it's only a 17 head. The block will still be 18 (1647cc)
    Still a good R12 transplant and it'll have the 5 sp box
    Berridale likes this.
    David Cavanagh
    34 KING St
    AIRPORT WEST
    VIC 3042
    Jerangle
    822
    Pretty sure it has a R16TS head as the water pump is at the back and the hoses go back.
    Probably wanted to put some life in the R18!
    i read the ad slowly..
    Simon's Avatar
    6,203
    Train-spotting and i read the ad slowly..
    The 15TS/17 also has the water pump at the flywheel end of the motor. Not train-spotting, and I've not read the advert. :-)
    1963 Renault R4 Van
    1964 Renault R4
    1000+ Posts J-man's Avatar
    Littlehampton, S.A.
    23,691
    Slight hijack but not entirely off topic .... who knows what lurked under the bonnets of the USA R12's? I saw this picture and noticed the bonnet hump suggesting maybe they were 1600 powered?
    cheers,
    John
    9,423
    Or just R17 bonetted?
    But you are right, they did have the 807/17TL engine. The 810 was probably considered too small for amerika.
    J-man likes this.
    ACHTUNG ALLES LOOKENPEEPERS
    Brisbane/Australia
    2,227
    The US versions of the R12 had the same engine as the Australian R18.
    Namely the non-crossflow 1647cc motor.
    Ren
    Dec 2010
    Blackburn Victoria
    505
    Quote Originally Posted by REN TIN TIN View Post
    Ren
    Evidenced by the bump in the bonnet over the carby.
    If it was a crossflow, bump would be on the right. Right?
    Cheers, Steve.
    9,423
    I think you're right.
    Brisbane/Australia
    2,227
    Yes, the hump is to clear the carb.
    I'd like to get a US spec engine (or an R18) to put into a 12.
    R15TS and R17 motors in a R12 are the usual but I don't know why but I like the 841 motor.
    Ren.
    J-man likes this.
    Littlehampton, S.A.
    23,691
Name:	Renault R12 1647cc engine.jpg
    Ren.
    I think that would make the humble Trojan a much nicer every day driver I found my Virage had to be pushed pretty hard up hills on the freeway, which of course it didn't mind but I think the 1600 would make it a more relaxed drive with easier overtaking
    cheers,
    John
    Simon's Avatar
    6,203
    Don't forget that the US spec 15xx & 16xx cc motors produce only a small amount of torque over and above the mighty 810/05 motor. Also they are heavier with heavier steering - I prefer the good 'ol 1289 motor :-)
    See the attached table for details:
    Attached Thumbnails Attached Thumbnails Engine and Gearbox for R12?-renault-12-engines.png
    1963 Renault R4 Van
    1964 Renault R4
    3,684
    You could get hold of an A6M which was 1647 cc with a crossflow head. The block was the same as the R18 block.
    They just put a plate on the end of the head where the water pump went on the 807 type motor and opened up the head at the other end and fitted the water pump and alternator on the front of the motor.
    I had on of these engines fitted to an R18 wagon with a Fuego 5 speed and rear axle.
    This car went extremely well, but still handled like a snow plough.
    I believe these engines were available in R18's and Fuegos etc in European markets.
    Simon's Avatar
    6,203
    Quote Originally Posted by 27of85 View Post
    4 x 4?
    1963 Renault R4 Van
    1964 Renault R4
    Brisbane/Australia
    2,227
    7.5:1 compression ration on the 841-10 motor!
    My god what sort of petrol do they have that needs a CR that low or did they have some California emission control laws that strangles the performance that much.
    3,684
    4 x 4?
    No it was only a normal one. I got the engine and gearbox from a wrecker, the engine and box came out a private import Fuego that had been wrapped around a traffic light pole. I was only looking for a bell housing at the time for 5 speed conversion.
    .2010 Holden Commodore Ute
    Feb 2001
    4,923
    It still lives on in my mates 18 sedan. it's on gas now and still flies.
    David Cavanagh
    34 KING St
    AIRPORT WEST
    VIC 3042
    tweed heads
    1,577
    And the gordini motor makes almost twice the hp and half as much again torque .
