High Beam ?
Results 1 to 3 of 3
Thread: High Beam ?
    Apr 2001
    Sydney, NSW, Australia
    14
    High Beam ?
    Hi ,
    I have a problem with my 205's high beam, well it's not worked since I had it.
    If you flash them when low beam is off then it works fine the high beam comes on, but once low beam is on and you flash them nothing happens.
    By flash i mean pull the lever towards the steering wheel I am not sure if this is the way thet work or not.
    Any ideas on how to fix this,
    Cheers.
    41
    This is a problem I had with a Renault 19 I had in the UK. This was fixed by replacing the headlight switch because even though the switch is still functional (ie lights switch on), its not fully working right. Don't know why cos its all electickery these days ...
    This was when I was living in Yorkshire in the country and needed to use highbeam all the time so it was a major pain in the a***.
    Paul
    "Indecision is the key to flexibility" Anon.
    Fellow Frogger! ipb205's Avatar
    Wright ACT
    585
    Try autofive.co.uk for a replacement combo switch. 30 pounds last time I checked.
    Might be cheaper than the dealer here.
    Ian
