505 Info required
Results 1 to 8 of 8
    Moderator Alan S's Avatar
    Queensland, Australia
    8,923
    505 Info required
    At the moment, I am thinking of buying another runaround & am looking at a CX Citroen & a Pug 505. Now the CX is no problem as I know them inside out but what about the 505??
    How good are they, what is their life expectancy & what sort of fuel consumption can I expect. How expensive (or cheap) are parts? How available non genuine & second hand? The Pug is a 5 speed. What are their weak spots?
    Don't want to look like a goose by asking a Pug owner when he last changed his LHM
    Alan S
    Feb 2001
    Romsey, Victoria, Australia
    4,923
    Alan, I question weather a Cit owner would be happy with a 505, compared to a CX, a 505 is a French Holden, now before I get abused, I know a little about both cars and both have good and bad parts, a 505 is basic easy to work on reliable, cheap on parts and easy to get parts, the base model has the old 504 motor and is very simple and reliable while latter cars had the OHC motor, basically the Renault motor and even the CX had a version with this motor, its much more powerful buts lets face it no one ever bought a 505 because of its performance. The CX is a limo compared to a 505, the ride, handling, quietness, smoothness of a CX makes the 505 look like a Holden and it would be hard to sell a 505 to a CX driver, on the other hand if a person wanted simple, basic, reliable no fuse transport that was easy to maintain and cheap to get parts for then a 505 is probably the best car for the job.
    Seeya,
    David.
    David Cavanagh
    03 9338 8191 or 03 93354008
    34 KING St
    AIRPORT WEST
    VIC 3042
    frenchconnect@bigpond.com
    Guru davemcbean's Avatar
    Apr 2001
    Camden NSW & Selwyn NZ
    2,343
    If you get a 505, just make sure you keep the oil in the gearbox well topped up and don't abuse the gearshift. Sometimes the gearboxes die, and it is often because either the gearbox oil level has not been checked in years, or the driver has tried to force the gearshift into gear on the odd occasion that it doesn't want to go in, resulting in breaking a piece out of the synchro selection mechanism, which then falls between the teeth on the gears and destroys the gearbox. Basically look after your 505 and it will look after you. Early carburettored cars are the simplest and cheapest to fix and are not that much slower than the fuel injected ones, if you give them plenty of revs (even though they sound loud, don't worry they won't blow up unless your doing 7000rpm+ or their low on oil or some other grose abuse).
    <font face="Verdana, Arial" size="2">Originally posted by Alan S:
    Alan S
    NZ Fleet
    1976 504 Ti
    1984 205 GT twin carb
    1991 205 SI 1.6GTI motor
    1994 106 Xsi
    1996 Mondeo V6
    Aus Fleet
    1955 203C
    Apr 2001
    2,343
    505 fuel consumption:
    22mpg driven hard in the city
    25mpg driven hard in the country
    28-33 driven easy in the country
    505 engine life expectancy:
    250-350,000km abused
    500,000km+ well looked after
    tailshaft life expectancy:
    30,000km very abused with no grease on splines
    500,000km+ splines greased and not abused
    Check for lash in the drive train usually caused by worn tailshaft splines. When they are very worn they will eventually strip resulting in loss of drive. Second hand ones aren't usually expensive. Generally (but not always) shafts from automatic cars are in better condition due to the smoother application of torque.
    Heads can sometimes corrode out quickly if corrosion inhibitor is not used.
    Check gearbox for noises:
    slight wine -not too bad
    rattly -probably needs new bearings
    Parts prices (not fitted):
    Head gasket $30-$40 approx
    5 major gearbox bearings $300
    rings and big end bearings $120-$200
    clutch $250-$300
    brakepads $45-$70
    Alan S
    NZ Fleet
    1976 504 Ti
    1994 106 Xsi
    1996 Mondeo V6
    Aus Fleet
    1955 203C
    Apr 2001
    2,343
    Those prices I mentioned were very approximate. They seemed to sit in those ranges for most of the 90s. With the introduction of the GST, some prices went down, but have gone up since due to currency fluctuations, so I'm not too sure what they are now. Generally 505 and 504 parts (they are really the same car with different sheet metal) are cheaper than many cars because of the fact that they made well over 4 million of these models and they are really popular in Africa, the Middle East and South America, with resulting good economies of scale. They still make approx 5000 504s per year in Nigeria.
    Alan S
    NZ Fleet
    1976 504 Ti
    1994 106 Xsi
    1996 Mondeo V6
    Aus Fleet
    1955 203C
    Fellow Frogger! petermc505's Avatar
    Melbourne, SE
    172
    Drive both cars, come up with your own opinion.
    I've Never heard of a 505 being referred to as a French Holden
    until now (interesting...)
    I can tell you though, my GTi will drive circles around your average commodore
    of the same year, goes well in a staight line too.
    I've never had anything serious go wrong either.
    9,223
    I'd agree that the 505 is a French Holden...
    Simple, basic, reliable, popular... in their homeland... and certainly compared to a Citroen.
    But anything French is a better handler than Holdens of that era, so don't be put off by this comment.
    Fellow Frogger! 406_SV's Avatar
    Queensland
    173
    I'm replacing my 505 GTi soon. You can come by and take it for a spin if you're around Bundaberg some time. It's an auto though.
    http://www.aussiefrogs.com/forum/showthread.php?t=10416
