205 GTi wheel offset.
Results 1 to 11 of 11
    Brisbane, QLD, Australia
    396
    G'day all,
    I have been looking at rims for the Pug, and have found the size as 4/108 15/25 mm offset.
    Can anyone tell me if thats a positive or negative 15/25 mm offset?
    Ta
    Chipper
    St Mary's Pennsylvania
    233
    who care's, they'll fit and look cool !
    396
    Dood,
    I know the 205 series two I have been looking for in those crooked NZ wrecker yards will fit.
    If I go aftermarket rims, is the offset - 15 or + 15 on the axis?
    233
    If you get some 15 or 16 inch Secta's(motofom I think) from a mag shop they'll do the alignment etc, with the price !
    Have a chat with Andreas he will probably know where you can get some adjustable camber caps for the front suspention.
    Fellow Frogger! Andreas's Avatar
    Sep 2000
    1,200
    actually i dont, i'll look into it though as i want to get them for the 405.
    btw your email didnt come through, your provider witheld it cos of the large attachment, i've asked for it to be forwarded.
    233
    I sent it via my work computer again, so you should have by now !!!!!
    396
    Camber caps? are these like a spacer or something to get the correct offset on an incorrect offset wheel?
    233
    No...... these are an adjustable bracket which house the top of the shock absorber.
    These caps can be adjusted clockwise or anti- clockwise to adjust camber.
    Excellent for club racing on a track with a lot of turns in one direction !!
    Apr 2001
    Sydney, Australia
    64
    Wheel offset is very important. if its wrong, your going to have horrid steering and go through steering racks every 6months to year. dont know what it should be but best find out what orignal specs are n compare.
    396
    205 Dude,
    Thats what I am trying to do !!
    I know its a 15 mm offset, another site had it as 15/25 mm.
    What I need to know is the 15 mm offset towards the inside or the outside of the rim?...as in where the hell do they measure the 15 mm from ???
    Anyone??
    Chipper
    jr
    jr is offline
    brisbane
    70
    the offset is the distance between the backface[the mounting surface of the wheel] and the centreline of the wheel,the distance is expressed in millimeters. the centre line is an imaginary line running right thru the middle of wheel looking down on it. a positive offset is referred to when the backface is located toward the front of the wheel relative to the centreline. a neg. offset is when the backface is located BEYOND the c/line toward the back of the wheel. offst can also be called the 'et' sorry cant make it any clearer. cheers jr
