Peugeot 505 SR Wagon
Results 1 to 3 of 3
    Murwillumbah,NSW,Australia
    1
    I live in Murwillumbah NSW (close to tweed heads) I need to locate a peugeot mechanic.
    I have a carbie problem ,keeps stalling at the lights or if I break hard, also when I go to take off with very light touch to the accelerator pedal. Some have suggested fuel pump problem.Can anyone help . Thank you
    May 2002
    Griffith
    76
    had similar problem with our 91 505 wagon. found the air intafe pipe from the engine to the air cleaner had a crack in it. Actually fount it by accident when I lent on the pipe when the engine was running and the engine ran rough and stopped.Fuel injected motor GTI.
    Nov 2001
    1,641
    How well is the car idling Dinabandhu?
    There can be a variety of causes for this sort of problem, and while carburtettors and fuel pumps are possibilities it may be something as simple as dirty ignition points, a defective sparkplug, or even a loose or dirty spark plug lead connector.
    Another very distinct (probably the most likely) possibility is a loose or cracked vacuum line.
    I'd be exploring these possibiulities before having work done on the fuel pump etc.
    Rod
    Rod's Home Page
    Rod's car page
