Hi All,
I thought I'd post here to see if anyone had any ideas about what is going on .... 'cos I'm scratching my head! A couple of weeks back the ****box rangie decided it wouldn't start (it had only been shut off for 5minutes while I picked up one of the kids).
It seemed to massively flood to the point where the car hydrolocked for a second after cranking for about 15seconds (in three five second bursts) ....I coulnd't get it started even though there seemed to be spark at the plugs. In desperation I unplugged the fuel pump (thinking maybe some injectors had stuck openO ... but still no go.
so went back the next day with fresh set of plugs to try and fire it up. It fired up very unhappily on gas. banging away on a hand full of cylinders ... So I drove it home banging away on probably 5 or 6 cylinders. Initially I thought something must have happened to flood the **** out of it. Now I'm starting to think the flooding was a side effect of something that broke/died when the car was shut off. It wets No 8 plug and sounded to miss all over the place "sort of". Its very hard to narrow down which cylinder is missing even by pulling the plug leads one at a time ( No 7 and No 8 seem to be the issue though)
I tried another set of plugs, checked the leads ..... Still crappy runinng on gas. In desperation I ordered in a compression gauge as I thought I must have damaged it when it hydrolocked (eg: bent conrods)
No 2: 135
No 4: 137
No 6: 137
No 8: 120
No 1: 140
No 3: 135
No 5: 135
No 7: 145
Low ... but certainly should run without any issues (well the gauge may read low to, it was only $23 delivered on ebay). So yesterday I checked all the HT leads, swapped the cap, rotor button, coil, ignition module with another car ... I even thought I better cover all bases and got No 1 at TDC .... made sure the rotor button was pointing and No 1 and checked the firing order (several times). It still sounds like its banging away on 6 cylinders and isn't happy. The only thing I haven't checked via substitution is the trigger wheel and sensor inside the dizzie. Does anyone have any ideas about what is going on here ? It seems to be No 7 and No 8 that don't wan't to fire. Given its running on LPG I completelly rule out issues with the fuel side ... it has fuel ... seems to have good spark ... has compression .... why no "bang" ?
I'm thinking its possible the cam timing moved when the motor hydro-locked. Does anyone know of a simple way of checking the cam timing? .......... I don't understand how it hydro-locking against the starter would hurt the valve train though .... both valves are shut on the cormpession stroke where the cylinder stops. The only thing I think this could do is cause a bent crank rod (which the compression check should show).
I'm rapidly running out of ideas here .... changing over the trigger wheel and sensor in the dizzie is my last desperate attempt to fix this (which I'm sure will make absolutely no difference
this afternoon I'll pull the rocker covers and check the valve operation .... and pull the dizzie back out and check the drive gear on the camshaft with a torch.... How can a simple petrol engine have me scratching my head like this
Oh, and I also checked the timing chain by rolling the motor forward and backwards .... there is no delay is movement of the rotor button... so in theory there is no slack/slop in the timing chain at all.
seeya
No 2: 135
No 4: 137
No 6: 137
No 8: 120
No 1: 140
No 3: 135
No 5: 135
No 7: 145
seeya
