Head corrosion was probably from using hard water although Bruce Tayler had a theory about the electric current from the fan clutch. Towns that use bore water were deadly. The thing that used to clog were the heaters.
what do you refer to as later models?One of the most common conversions I perform to 504's in my workshop is to fit later 505 cross-flow radiators. This not only dramatically improves cooling efficiency but also allows the running of a 13psi Cap. The addition of an expansion bottle also reduces the need to frequentlyTop-up the cooling system.
Paris
why does the larger radiator allow a higher pressure in the system?One of the most common conversions I perform to 504's in my workshop is to fit later 505 cross-flow radiators. This not only dramatically improves cooling efficiency but also allows the running of a 13psi Cap. The addition of an expansion bottle also reduces the need to frequentlyTop-up the cooling system.
Paris
