That is easy. Peugeot decided voiturette (light car) racing was not enough, and chose to try grandes épreuves (grand touring). They did so with an engineering tour de force: a (DOHC) 7.6-liter four-cylinder (110x200 mm) with four valves per cylinder. It proved faster than other cars of its time, and Boillot won the 1912 French Grand Prix at an average of 68.45 mph (110.2 km/h),
what car was this v12 diesel in that sounds insane?Probably the v12 diesel hybrid it had over 800hp from memory
oh man those really early like 10 liter inline 4's really get my vigor up. I believe there was a FIAT unit in the '10s sometime that was a 16L inline four, pistons the size of your head.That is easy. Peugeot decided voiturette (light car) racing was not enough, and chose to try grandes épreuves (grand touring). They did so with an engineering tour de force: a (DOHC) 7.6-liter four-cylinder (110x200 mm) with four valves per cylinder. It proved faster than other cars of its time, and Boillot won the 1912 French Grand Prix at an average of 68.45 mph (110.2 km/h),
wild, didn't know there were diesel racers at le mans. Part of me has always wanted to see a proper, high profile racing series without engineering restrictions, like F1 but vacuum cars are allowed, you can use whatever crazy fuel you want, can be electric if you think it'd win, as big or small as you'd like, just to see what pace can be had without the restrictions.I think the below refers to the non-hybrid version of the same engine. Version of the engine also appeared in a concept car. The Hybrid version added 80 hp.
https://en.wikipedia.org/wiki/Peugeot_908_HDi_FAP
"The Peugeot 908 is powered by a 5.5 L (340 cu in) HDi diesel engine, the maximum size allowed by Le Mans Prototype rules. Its configuration is a 100° V12, the angle having been chosen to lower the center of gravity. Its output has been revealed to be over 730 horsepower (540 kW) and 1,200 N⋅m (890 lbf⋅ft) of torque, nearly 10% more than Audi's similar R10 TDI.[8]"
I wonder if peugeot or any french marque other than bugatti will ever put out a proper supercar. I've seen some of those peugeot supercar concepts and they look absolutely bangin', like the Quasar, which i can hardly believe is based on a 205. Maybe i'll make a kit quasar one day in the deep future.
Depends how good they are to drive. I've heard good things about those tiny enginesIt's sad that the largest petrol engine they make now is barely a 1.6L
I wonder how much of this is just a holdover of attitudes from before forced induction was commonplace on every new engine. I think younger buyers are more enticed by smaller, economical engine, but with how the economy's set up, younger buyers are becoming rarer and rarer, as well as the prevalence of uber et al. Of course this all goes out the window with commercial vehicles, you just need max capacity with min fuel consumption there, to hell with the driving experience.Buyers who compare specifications often see the larger engine of competitors at the same price as an advantage. Cars were once grouped in classes by engine capacity. Although an increasing number of buyers have little interest in engine specifications. I presume it is possible to gain better fuel efficiency with a smaller capacity although the gain in that is lost if the engine requires a higher grade of fuel than 91. In the light commercial field engine capacity remains important and new model utilities are not fitted with smaller engines used in European markets.
