Stretched conrod bolt
PugMonkey
Well-known member
Hi all,
Back into building my engine but struck an issue. I have stretched a conrod bolt. What can I do? New conrod or can an engineer replace the thread? Can't post a Pic yet.
Sent from my HTC One M9 using aussiefrogs mobile app
Buy a new conrod bolt. They aren't very expensive. How do you know you stretched it? Were you using a conrod micrometer?
I was torquing it down and it just didn't want to tighten so I undid the nut to discover the stretch. Torque used was 39 ft lb from memory
Just as an aside, years back we used to prepare vintage racing engines with new hi tensile Allen head socket bolts secured with hi tensile nylock style nuts as you could not buy the hi tensile replacement conrod bolts, they worked better than trying to use old deformed conrod bolts, none of the Allen bolts failed in service. here is a link to available similar hi tensile similar bolts.
https://www.bing.com/images/search?q=Bolt+Tensile+Strength+Tables&FORM=RESTAB
Ken
It sounds like you've "stripped" the thread rather than stretched the bolt. Stuffed nether the less. You could either buy one new rod bolt & nut from Peugeot, or a complete set of ARP bolts from someone like Rocket Industries. I'd probably do the later. Price will be similar I'd expect.
I'd also replace the clutch pressure plate bolts, these do stretch as I have found.
Pic. Thread is not stripped. I have another con rod to use. 1565253581649.jpeg
Definitely past it's yield point! You don't need a micrometer to work that out. Great steel though.
