Hi Everyone,
Wonder if I could get some advice...I have overhead cam engine that is leaking profusely from the rocker covers (not a citroen - hope that's ok )
The oil appears to be coming from the joint along the rocker cover where the two gaskets meet (or probably don't quite meet). The photo below shows the top of the rocker cover, and naturally, the leak is on the opposite side underneath.
So what to do? The gaskets seems in good order, so likely a waste of time and money sourcing new ones (which are not cheap!) So do I try a skim of silicon, or pehaps hylomar? And do I need to worry about being able to remove what ever I use from the head at a later date if necessary?
Andrew
Andrew
