Yep, I can't be bothered resizing images to put it up on here so I just post it to the Aussie frogs Facebook group.looks like i need to join FB, oh to also haunt you know who.
I wouldn't feel too bad about it. There are too many things out of your control to worry about. That crack seems to me more like a manufacturing defect. These are old castings coming off an assembly line where people work against the clock, so many points of failure it's all about how lucky you are when you buy a car like these at 30-40 years old.
I am not sure the gasket can restrict flow enough to cause problems but if I had any concerns, I would try to enlarge the passages in the gasket to match the castings. Kinda like matching a manifold to a head. A few minutes with a sharp scalpel should do it. Just make sure you match the gasket against both block and head so you take into account any misalignment between these. Also check you're not cutting into the strips of silicone or whatever that sealing material is if your gasket has it. Shouldn't be the case, because if the sealant strip is so close to the passage or goes inside the passage, the gasket won't seal (or won't make use of the strip) anyway but just for peace of mind. If the sealant strip seems to fall inside the passage contour I would deem it useless and try to return it.
Not exactly the result you'd like to see after all the work you put in, but I guess these things happen. Keep going.
A few years back, I had an S16 in which the head which cracked in the exactly the same place as in your picture. Out of the blue (i.e., not related to any other event such as an engine rebuild). The engine immediately began to run hot with coolant leaking into number 2 (or 3) cylinder. I did not need to do a pressure test - it was obvious from the spark plug which cylinder had the problem which was confirmed when I removed the head. There was no evidence of head gasket breakdown. I took the head to a trusted engine rebuild shop who said the crack was not repairable (which I did not necessarily believe) but I was able to find a replacement head that had just been rebuilt and fitted that instead - problem solved. I also fitted a new clutch kit at the same time.Well. I haven't posted here in a long time. Mostly out of sheer shame, but also I haven't had the will to look at this thing.
But not even 500kms in, I had overheating... Did a bunch of tests, still the issue persisted... Finally bit the bullet and did the chemical test to see if combustion gasses in the coolant. Yep.
Then did leak-down. Yep, one chamber pushed coolant out of the rad. Confirmed. Ripped the head off, found this juicy little crack. I'm not sure if I reassembled the build with a defective head (it wasn't pressure tested under water which I regret), or it cracked shortly after, or if the higher compression stressed it.
I have another another head which I can use, but will need to get it serviced. I don't like the guys who I got work done with. They're a bit of a shambles - too much work and I'm sure they rush stuff.
Questions
1. Has this happened to anyone with this build?
2. Can anyone recommend a good machine shop that take their time, respect the customer - I'm in Wollongong but can travel to Syd, Canberra etc?
3. Also, what head gasket are you using - the Ajusa one doesn't seem to maximise the full width of the channels...(can sort of see from the gasket residue) I wonder if that leads less effective cooling.
View attachment 199873View attachment 199874View attachment 199875View attachment 199876
Thanks John - good to know it just 'happens' sometimes.A few years back, I had an S16 in which the head which cracked in the exactly the same place as in your picture. Out of the blue (i.e., not related to any other event such as an engine rebuild). The engine immediately began to run hot with coolant leaking into number 2 (or 3) cylinder. I did not need to do a pressure test - it was obvious from the spark plug which cylinder had the problem which was confirmed when I removed the head. There was no evidence of head gasket breakdown. I took the head to a trusted engine rebuild shop who said the crack was not repairable (which I did not necessarily believe) but I was able to find a replacement head that had just been rebuilt and fitted that instead - problem solved. I also fitted a new clutch kit at the same time.
Regarding gaskets, I used whatever EAI supplied and I certainly did not "clean up" the gasket around the oil and water galleries - not necessary in my opinion and not the cause of your problem.
I would take Peter T up on his offer to use his engine rebuilder.
My S16 met its demise a few months later when the engine loom chaffed around the front of the block resulting in a fire in the engine bay. My fault I think as I was not careful enough in placing the wiring loom around the corner of the block near the starter motor. The engine and gearbox was not damaged and I am planning to fit this unit into an engineless S16 I purchased a few years back so another S16 will be saved.
JohnT
