Restoration - 17ts
@Shoji yeah this cluster style is cars made after March 1976 only
@Simon Gee, that would be great if it’s otherwise being unused… I’m sure it’ll come in handy.
Cluster has a burnt out main earth trace, choke light + feed was broken as was + feed for the clock. Reran the traces, cleaned some bulb holders and all is good now.
It was earthing through the positive feed of the high beam light in the end, as the main earth connection was dead.
Battery guage appears dead, and the (I assume dash backlight brightness dial, in the tacho housing? I could just read the manual…) doesn’t do anything. I can live with that though.
If those jumper wires are factory, yield on the circuit boards must have been very bad, there are entire traces cut away from the PCB!
No intention to go to higher wattage bulbs… the friend of mine who did the soldering converted his XC Falcon dash to LED, as LEDs are diodes so the electricity can only flow one way… I don’t like the look. Too sterile and bright.
Anyway, back in action.
The connections to the battery need attention, the plastic threads are flogged out on the terminal doo-dads. I think I’ll just remake the entire loom, it’s only two wires and some ring terminals.
So, when I had the cluster out, I realised it’s wired for the fog light circuit, but there’s no bulb, or wiring for the loom side of the circuit.
My uncle installed these Cibie LED fog lights at some point. They’re not wired in.
May as well hook the circuit up I guess.
Where can I get a fog light switch from? Was it shared with other models? Can’t find one on various websites (cipere etc)
Does anyone have a photo of where it goes or how it’s meant to look?
Also, it’s got a rattle in the muffler. Will need to have that replaced…
I've just checked the parts catalogue. The battery (voltmeter) gauge is the same as a Series 1 Renault 20, so whilst not exactly thick on the ground, at least there is a possibility of finding one locally.
With the original plastic battery "nuts" it is worth a try putting a helicoil into the plastic, it makes them more durable. With some of them there is just enough meat, so go carefully. It is always nice to see the original connectors - which now seem quite rare.
The fog light switch has three part numbers. The first two are supply until stocks exhausted. 7700 635 645, 7700 641 896 & 7700 646 030.
In addition to the above, what switches are on the extreme right side of the dashboard. Where it appears there are spaces for a driving/foglight switch on the 15GTL and a sunroof switch. Your car may have blanks in that location where a switch could be fitted.
That would be right :-) The attached pic is what I was hoping to see, switch blanks for where the driving/fog light and sunroof switches would be. Looking at the parts catalogue, it looks like the whole cluster surround is one piece. I was hoping just the pocket may be able to be replaced by the switch panel, but that doesn't seem to be the case.
