All N.O.S. unless noted. 4x330 g/box main Brgs,
4x synchro cones
1x tailight n/plate lamp perfect
2x sets c/r brgs Std
1x set mains Std
20x valve colletts
10x valve springs
4x ex valves
7x In valves
1xg/box mainshaft 555779700
3x rear axle seals
1x speedo drive
1x set early Ducellier points
1x m/cyl kit
2x carb base insulators
4x carb base gskt
1x electrical connector
1x m/cyl seal kit
2x rear b/cyl kits
1x distributor Excellent
1x Hella spotlamp needs work
$200 PLUS FREIGHT THE LOT.
4x synchro cones
1x set mains Std
20x valve colletts
10x valve springs
4x ex valves
7x In valves
3x rear axle seals
1x speedo drive
1x m/cyl kit
4x carb base gskt
1x m/cyl seal kit
2x rear b/cyl kits
