Hey guys,
I have the drivetrain from an R18 turbo which I have just found out is in quite good condition (good clean head, perfect liners-still got honing marks etc). I am also about to acquire an R17 for free. Hence I am (as you do head_ban ) starting to think about putting the turbo motor into the 17.
My dilemma is this- do I keep the original 17 brakes, a-arms struts etc or try and bolt all these things on from the 18.
I have checked the specs and they are nearly identical, with the R17- 8.98in and the R18- 8.976in(the brake sizes)- so no real advantage there.
The only difference I can make out is that the 18 has a twin circuit (diagonal) brake system whereas the 17 has a single one...
As much as anything I was thinking about it from the point of view that it would be easier to work on the shocks and springs on the front with the 18 strut/sping in it...
The track measurements are quite different between the two cars though....
The 17 is;
(Front track) 1.34m
(rear track)1.31m
The 18 is;
(Front track) 1.41m
(rear track) 1.35m
So that would equate to 3.5cm per side difference... on the front anyway.
If this idea does come to fruition (it depends on how rusty the 17 is!!) it will be used for a rally car- so it doesn't have to look pretty - just work well! The acutal conversion (engine/box mounts) doesn't phase me too much- as we pretty much already did this for my 17 with the fuego motor(1647cc) and NG1 (5spd box).
The only other thing is that the radiator end tanks are buggered (plastic ones).
Does anyone know if can you get aluminium ones made up? or are we talking moonbeams....
eek!
Oh, one more thing I have a std 1565cc head gasket for an 807-10. The 18 turbo one has an extra piece for a dowel that is located at the flywheel end. All I can figure is that it helps locate the gasket, it's not near any oil or water galleries, so could I get away with using this gasket?....I am not certain at this stage that I can get another 18 turbo gasket...
Cheers for any thoughts...
ps my apologies if this has been posted about before- I am pretty sure it hasn't though... Hey Ash- your loss dude- the motor turned out to be a good 'un! wink
The 17 is;
(Front track) 1.34m
(rear track)1.31m
The 18 is;
(Front track) 1.41m
(rear track) 1.35m
eek!
