Hello everyone,
The issue I'm currently having is that the car is stuttering when under load (eg putting the foot down to overtake or trying to change down and accelerate up on a hill). This doesn't ALWAYS happen but mostly it does. The car has had a lot of work done on it and I've complained about this issue to the mechanics a few times with no resolve (possibly because there is no code showing?). Could this be as simple as a dirty MAF or a faulty coil? Seems unbelievable that these wouldn't have been checked by the mechanics??
So far I have had the following fixed within the first 6 months of ownership (mostly covered under stat warranty thankfully):
- Oil Filter mounting Leak
- Thermostat housing Leak
- Coolant level sensor
- Oil pressure sensor
- Cylinder head cover
- Window washer (done twice)
- High Pressure Fuel pump
- ECU update (part of a recall)
- Engine Oil Pump Solenoid replaced
- Intake Valves bead blasted
- Spark plugs replaced
The car also start eating oil requiring a top up every 2 weeks. At the same time I noticed there would sometimes be a puff of white smoke from the exhaust when I moved away after sitting at the lights for awhile. The shop reckons the solenoid replacement should have fixed these issues although I'm waiting for the low oil warning to come on again and/or another puff of smoke....
If anyone else has had this stuttering issue and knows of a resolve it would be much appreciated.
Thanks!
I'm having a love hate relationship with my 2011 308 Sportium wagon which is both awesome and terrible.
I'm hoping someone is able to help me out with my current problem as the usual searches haven't turned up a solution and neither have the mechanics. The issue I'm currently having is that the car is stuttering when under load (eg putting the foot down to overtake or trying to change down and accelerate up on a hill). This doesn't ALWAYS happen but mostly it does. The car has had a lot of work done on it and I've complained about this issue to the mechanics a few times with no resolve (possibly because there is no code showing?). Could this be as simple as a dirty MAF or a faulty coil? Seems unbelievable that these wouldn't have been checked by the mechanics??
(part of a recall)
- Turbo intake pipe replaced (had a worn seal)- Intake Valves bead blasted
Thanks!
