Hi Everyone,
For those of you watching the restoration threads, my GS wagon "The Orange Peril" is nearly finished, and going for it's pre-registration inspection tomorrow. I've had the car since 2008, and it was in pieces and partially restored when I took ownership of it. So fingers crossed there will be no major surprises when it finally gets to stretch it's legs again.
Next project is to recommission the Birotor. It stopped around 10 years ago due to water getting into one of the combustion chambers. It could be "just" a blown o-ring, but I am fearing the worse, as the spare casing I have also show sign of corrosion of the aluminum around water chambers.
I have a brand new motor in a box, and also a pile of spare parts from another couple of motors. The easy way forward would, of course, be to use the spare. But first, I am going to have a shot at building up a motor from the pile of spares, ideally using the original motor that came with the car.
So, does anyone know if there any surviving records on the Birotor that would list the engine number and body number of each car, so that I can see if I do indeed have the original motor?
Andrew
Andrew
