Finally tried out my Lexia cable with PP2000 on the 407 today.
It completely failed to recognise any of the cars BSI/ECU's
The cable I have is NOT the full chip version, but it at least recognises the engine ECU on my daughters 307. It also worked fine on ym 206GTi.
SO I am not sure if it is the cable, the software, or the selection of car that is responsible. Anyone able to help?
When I get into pp2000/diagbox and enter the VIN, it wants me to select the model of car I have the following options:
407 saloon or estate with an old generation BSI
407 hatchback or estate with a cross range BSI
407 coupe fitted with a cross range BSI
407 hatchback or estate with a modified BSI
407 coupe with a modified BSI
As I have a saloon, there is only one option, which is what I selected (never seen a hatchback).
I can verify that the OBD port works, because it did respond when I plugged in a generic ELM327 OBD dongle
So can anyone shed light on what is at fault? Any troubleshooting tips?
I am getting close to just buying a new full chip cable set as they are so cheap these days.
