Peugeot 306 convertible- how to replace zipped window
jonk
New member
Sunbury Vic.
Hello all,
Could anyone advise how i can remove the zipped rear window of my Peugeot 306 rag top?
Any help would be appreciated.
John Karagiannidis
Peel the fabric away its just taped to the window and the zip will be evident, removing is easy and zip starts and finishes at middle bottom.
Refitting is the reverse and be prepared to fit it numerous times t make it sit correctly. Tape it back up and your done , will no be as simple as that but you have to experience it. Not impossible either.
Just check closely to make sure there haven't been a few stitches put in to make sure the zip doesn't come undone accidentally. Could well be the case if it's been replaced before.
