Peugeot 207 GTI 2007 model
Problem solved installed high pressure fuel pump brand new IMG_1584674905.695233.jpgIMG_1584674916.359597.jpg
Old one;
Thanx everyone I finally replaced it. It seem to help the car run a lot better n sound better.
Aaa pls i have the same problem and I can't find the knock sensor can you pls give me some info as I want to replace it myself location and from top or bottom thanks in advance cheers Paco
The EP6/EP6DT knock sensor is a piezo device mounted on the block, centre rear, under the inlet plastic. Item 7. They don't give much trouble.
