So changing the oil and the filter I found some problems. LH outer driveshaft boot is split and spraying grease all over the place. RHD lower wishbone rear ball joint is worn (split rubber? - not sure if it's just a boot or some sort of bushing that encapsulates the ball joint, whatever, needs to be changed).
Now, I had a look in the manual but couldn't find anything to say how to do these jobs or if it is even possible. I have found instructions how to remove both the driveshaft and the suspension arm, but nothing about replacing a ball joint or a boot.
I suspect Renault would have you replace the entire driveshaft and the entire lower suspension arm but I imagine these bits won't be cheap so would prefer to replace only the defective parts.
If anyone has any experience or knows how to do these jobs, please illuminate. Where to buy parts would be useful as well.
And another issue that occurred to me while lying on my back under the car on the cold cement of the driveway. Does this thing (diesel engine, I suppose M9R) have a timing chain or a belt? Couldn't find anything in the manual.
PS. But look what I found on the interwebs:
Phew. Thank god (and Renault) I won't have to do that any time soon (hopefully).
Does anyone know why he is inserting that tool in the side of the block when taking off the front pulley? I suspect to immobilise the crank but wonder how that is achieved, maybe pushing against one of the webs?
