...you crazy guy :roflmao:
Getting lighter.
Dash and engine / body loom was worth 40kgs! https://photos.app.goo.gl/NTPSGpYFyqSG1r217 I want to see a 6 at the start there... Knowing a cage will add 100kg easy. There are still a few brackets left around to liberate, and it still has the original heavy battery, and there are heads of new longer steel bolts I can replace with some shorter ones..
Oh and the door handles,
Oh and the side vents,
Oh and the boot brackets for the jack etc,
Oh yeah I reckon this will work
bo1636573 said:I was thinking it was only this bad after removing the headlights. I now have these great big vents in the front that must be directing air in. I was thinking about making some exhaust vents up into the plenum, or outside the guards (perhaps where they usually rust) in effort to direct air somewhere.
But first to test the theory, I'll make some blanking plates and fill those gaps and see what happens.
wie;
The double sided tape and bits of aluminium is a great idea however!
Agree re the braking. I still need to put the venter 17discs on it too! I just need to braver.
You only moved the rear outwards a couple of mm? some back of hand measurements would suggest I would need 50, 60mm to get about 2 degree at the front.
