I had a 1924 Bean 14, I sold last year, 2.3L side valve 4 with 75mm bore 135mm stroke. Revved to 4K, not earth shattering engine revs but I reckon the piston speed would have been getting right up there.Long indeed.
But not too bad. With a bore to stroke ratio of .78/1 there's still hope.
You wonder how the heck they managed to keep the compression so low with such a stroke, probably a combustion chamber the size of an airport hangar. I'm sure there's a lot of power to be found in this engine.
Most inappropriate discussion.I had a 1924 Bean 14, I sold last year, 2.3L side valve 4 with 75mm bore 135mm stroke. Revved to 4K, not earth shattering engine revs but I reckon the piston speed would have been getting right up there.
The long stroke and heavy flywheel in the early Dees would limit any major performance improvement other than via forced induction.
Safe speed limit for a (average design) cast alloy piston is considered to be 3500 FPM. The long stroke engine would be approaching this speed at 5000 rpm.
There may be scope for minor improvements in carburation and exhaust but any serious work would require a total rebuild with lighter more modern design forged pistons to safely permit higher RPMs.
The 80hp long stroke is quite unusual (for an old tech engine) in that it carries very close to maximum torque from 2750 through to 4250 rpm. 4500 is max hp rpm. Very few old school engines carried so much of their torque so close to their max hp RPMs. Any engine mods (other than forced induction) would see this flexibility start to dissappear.
Now now, the last paragraph states the exact reason you should leave a good thing well enough alone.Most inappropriate discussion.
Offensive sentiments.
Please, someone remove this!
Yes, as I stated earlier with my 88hp short stroke, it hill climbs well in top gear if I get it to 3000 rpm before I hit the incline. 2500 rpm and I'm looking for 3rd gear in short order.Some of the usability comes from the twin throat carburettors that allow economical high speed cruising but sufficient through put of air to ensure WHEN the second throat is opened ( via a feelable right foot pedal ) there is good air flow. IDs with the Solex carburettors required more planning when an overtaking manoeuvre was anticipated. Much like using the momentum when driving a 2CV. It used to be called "road craft"...and a well driven 2CV on twisting roads can be a revelation for how much it can do with so little power.
…required more planning when an overtaking manoeuvre was anticipated. It used to be called "road craft"...
I did some overtaking in my DS only last week, flew past them like they were hardly moving!
Overtaking…. I did that yesterday! But it was on a 4 lane motorway… took me a fair way to do it .
I guess then I should be thankful I look a bit like Karl Marx.They are just poseurs ... NO BEARDS
And no elbow patches on the jackets…They are just poseurs ... NO BEARDS
