I suspect another trip to Jamie's is called-for - to look at his Ambulance?Yes please. No doubt I am doing something wrong.
Babadec, here some photos... not sure what could be wrong on yours.Yes please. No doubt I am doing something wrong.
Trick question? Maybe not... I cleaned all the holes and blown compressed air through it. Are the chambers under the weights? Haven’t taken them off, but can of course.You have cleaned out the big end chambers in the crank, haven't you?
The centrifugal oil cleaners are often close to blocking up.
It just isn’t on the photos John. The gaskets are in place and under the bearing caps , plus sealant to hopefully keep all the oil in - but I am a bit nervous as the cork gasket strips that sit over the bearing housings needed a bit of trimming (they were a little too long) and a fair amount of force from tightening the sump screws to press the ridge from the sump into the cork.... I hope we did it correctly. Would be a bugger to find it leaking...I have one concern. In the photograph of the crank installed, I don't see the sump gasket in place. I believe you should assemble the sump gasket to the block so that the cork ends are actually underneath the #1 and #3 main bearing caps. If you don't do it this way, you will have oil leaks front and back (don't ask me how I know this)...
