• Tapatalk and Mobile iOS/ Android APPs no longer supported on aussiefrogs.com. Please delete on your device. Use the web interface instead.
badabec
Yes, saw that. With the double angle bracket I was given I will be able to move the bolt hole just that little bit further out so that the hole (and therefore the nut) is between the outer closing panel and the outer sill panel that I can access from underneath. Your spot is between the inner and outer sill plates, difficult to access. Will play with it and take some photos.
You could use a 30mm hole saw, weld a plate with the nut in position then weld the hole up again.
bleudanube
Time for an update after a few weeks of Sunday fiddling. Finished the rear left corner and have started on the final area, the front left sill and floor.
The rear came up ok, it was after all a tad easier than the right hand rear.
The front floor and sill area needs the most work of all - foot rest panel, seat panel, inner and both outer sills, the whole jacking point with inner strengthening bracket, floor section and finally the strengthening plate...
So over the past weekends I replaced a section of the seat floor and the foot rest panel. Started with a cardboard template and then made up the panels and welded them in place.
Then onto the inner sill and the jacking point bracket. Welding the sill in from the inside meant less grinding for once... phew.
A few more weeks and it should be finished.
Sven
bleudanube
So close! I can see the end in sight!
After two days of solid work I have a floor again - woohoo! Finished the jacking point, the internal bracket took a bit of persuading to get the fit right... too many wonky angles to battle.
Then the inner and outer outer sill were reasonably straight forward, cut the holes for the jacking stand et al with a die grinder. Still need to tidy up all the welds - next weekend job. There is still a lot of grinding left...
Then the final masterpiece - the remaining floor panel. It fit like a glove and looks fantastic. It is such a relief to end up at this point after over a year of fiddling with the car. I am estimating that I have spent probably 400hrs on the chassis to date.
There are a few small areas to finish, then onto the filler work to tidy up some of the welded areas that will be visible and then seam sealing and underbody protection.
bleudanube
Finally! After months of cutting, welding and grinding the heavy lifting on the chassis has been completed! What a relief. Thought I never get there...
The floor looks really good, especially after tidying up the last of the underbody remnants.
So I started on the next job: some of the areas where I welded in panels using the lap joint method I need to use some filler to smooth out the joins. Even though it will all be covered by carpets or vinyl - it needs to look right.
Also started using seam sealer on some of the joins. Using being Teroson caulking sealer and then use a small brush to level it out and make it look a bit like the tar-like stuff the French used in 1964.
Also thought it might be quite cute to put a few before and after shots up: here the jacking point before (or what was left of it) and after.
Bit of a difference ...
Sven
bleudanube
Another before and after - this time the front floor. Here what it looked like before: in some areas I had four layers of “floors” to cut out.
A little better now:
Rewarding....
Sven
