Cheers guys.
Today I pressed the new bearings onto the motor shaft with a vise and then the pinion gear after it was inserted into and through the grease seal in the underside of the motor mounting plate. Checked the length of the original brushes: 6 mm and 9 mm....too short, so I looked in my spare parts stock and found two new or nearly new ones, both 12 mm long. Then the motor was tested and it was SO smooth!
Next task: the hydraulic part of the pump, which sits below the electrical part.
