Meanwhile over at the tyre shop
Hankook R-S4 $415 fitted and balanced
Thanks Richard, that sounds very helpful. Whoever did this to little silver put an additional central locking solenoid in the drivers door piggybacked off the factory one to simulate what happens when you turn the key. It must be out of adjustment or worn and just a bad idea as last time I tried to use it, it kept triggering itself up and down like a yo-yo! now I know why, but at the time it was pretty funny to watch.
My notes suggest that wire carrying the "unlock" signal into the central locking controller module from the remote receiver is numbered 203, and the wire carrying the "lock" signal is numbered 204. On my car I removed those wires from the controller down near the steering column and connected up the 'lock' and 'unlock' signals from the immobiliser instead and, hey presto, the remote control on the immobiliser now controls the factory central locking.
A phase one 205 never had remote central locking in the first place so maybe it won't have those same wires and terminals?
I've got a spare phase 2 central locking controller box here that does have the right terminals if that would be any use.
Here's a diagram for the wiring for the controller. I can also scan and sent my translations but it's pretty rough: http://aws-cf.caradisiac.com/prod/mesimages/1003540/boitie101.jpg
Yes Moe, the new owner of Little Silver had them painted, they look very nice!Very nice. Have they been refurbed because they look great!
Lucky the broken mount stud came out easily.
Looks like a crack in the bottom of the mount socket - you need to plate that and weld it up.
Justin
I had the same issue with the 306 cab. Just weld a plate over the top.Nice pickup Justin!
I did notice something but hadn’t had a chance to get in there with a wire brush to clean it properly yet to check the extent of the damage. I’ll report back on what I find, from the photo I agree.
The car is having some welding done soon so it will go on the list.
cheers
Craig
And it looks like someone had a go at welding that crack before.
I wonder what can possibly crack the body there and how? Looks like a fatigue crack, so possibly repeated flexing, but how, because a flexible rubber mount shouldn't transmit force.
All 2 litre 306's will crack there as well. Just a design fault. Later models have MUCH stronger engine to chassis arrangements for that mount.
Justin
