Trying to wire up a new coil ! I have installed an optical points thingy, having trouble with the installation of the blaster coil (40000 volts).
The wiring loom to the original coil is on a multi plug. I have identified the + and - on the plug and have run wires to the corresponding + and - mounts on the coil.
Tried to start it and there was a massive power drain, engine not turning and smoke from under the dash !!!
