I have just finished putting the new barrels and pistons into my 1220 motor, reassembled it and when I tried to build up oil pressure before actually starting it, got no response. Before I pulled it down, the oil pressure was fine. During the rebuild I did not disturb anything in the crankcase or the oil pump. I had the motor on a Rotary stand, and turned it on to each side to install the barrels vertically , thus presumably removing any residual oil from the oil pump. The motor was dry for about three days. It seems that the oil pump is not drawing oil from the sump. I removed the oil filter and tried to prime it with oil through the gallery from the filter to the pump, then turned it over again and still have no oil pressure. Is there a technique to prime these oil pumps or have I got a bigger problem? Thanks. Ian.
