Hi have a 206 gti 2002 model with fuel gauge inoperative any one had this issue any ideas the you
P Parer555 New member Tadpole Joined Jun 17, 2018 Messages 3 Location Wentworthfalls nsw Jul 22, 2018 #1 Hi have a 206 gti 2002 model with fuel gauge inoperative any one had this issue any ideas the you
SLC206 sans witticism 1000+ Posts Fellow Frogger Joined Sep 13, 2003 Messages 4,288 Location North Parramatta Jul 23, 2018 #2 Well, the most obvious answer is that the fuel sender is stuffed, however it may be that the connector just needs cleaning. The sender is part of the fuel pump assembly. It's got a long metal arm on a float that moves up and down with fuel level. You'll find it under a black plastic cover underneath the back seat (driver's side, from memory). Try cleaning the sockets of the connector and see if that fixes it before attempting to remove the pump unit.
