There is a major fault with Tractions gearboxes that Gerry may be able to explain better than me. But one of CCOCA's members, Bernie Hadaway ( also recently deceased ) had observed that one of the gears ( second I think ) has a sharp edge when being cut which was a modification by Citroen engineers made on the assembly line - but this undercut creates a stress point and eventually creates a weak point. Bernie had a solution which added another bronze bearing to this area which solved the design problem. I will try and find this article from CCOCA records and post it here. With the gearbox apart it would be worth considering the modification. There is also the Jack weaver strengthening plate which can be fitted internally to stop the gearbox casing cracking from within. Details of these are still available.
Over to Gerry for his thought.
Hawk
(Ted Cross)
The gears were machined with a point lead for the first /reverse sliding pinion and its matching engaging gears. It slowly becomes rounded as people clash the gears when engaging. The dog clutches on second and third idler pinions are also cut with a pointed lead to allow the splines of the synchro outer hub to lock over and engage. The break in Shanes box is very unusual as it is usually the second/reverse idler cluster on the mainshaft that breaks. It does this as of the tow sets of gears that are constantly engaged it is the smaller and therefore more highly loaded. The other factor at work is the fact that inside this cluster are two bronze bushes pressed in the bore from either end. These do not meet in the centre of the gear in order to form an oil well. Unfortunately they are prone to moving with age to close the center oil well space. This means that the gear is supported on the shaft incorrectly and can then wobble out of concentricity in relation to the mainshaft. The gear can then load up out of contact with the full face of its engaging pinion shaft gear. Point loadings and high stress occur under a shock load from the driven wheels ( ie hitting a pothole under power in second gear ) and the tooth breaks off.
It is a situation easy to rectify. Either fit new gear bushes and Loctite them in place or modify the floating bush from the pinion shaft to make a single piece bush for the second/reverse idler. It too can be loctited in and the oil supply holes drilled for lubrication. This one piece bush needs the be reduced on the OD to fit and then cut to length to match the second/reverse idler gear.
Ted I think that Bernie was 'Tilting at Windmills' with his theory.
As for the strengthening plate-----if you are going to race it OK but a properly built box is very strong with out it. The plate fixed to an improperly built box may save the case from splitting but the damage can still happen to the gears.
Of most importance is pinion shaft depth setting and assembly integrity. Throw away the multi tab washer from behind the pinion nut and ensure that the C locking rings are unmarked on the side that bears on the splines of the pinion shaft. If one side of these is worn it is permissible to turn them around the other way so that the unworn side is now providing accurate lock up when the assembly is tightened.
