And now for the million and one pictures .... in the hope that I'll be able to figure out how the hell it goes back together in 3months time when we get back to it
It's already removed from the car, the top cover is off, and the front lower nut cover ( removed ages ago to tighten up the big nut with big bars to see if that solved the noise in the gearbox).
My concern is why was there broken teeth on a gear in there. I hadn't realised when my father bought the car, it had trashed a driveshaft. So no doubt a shock load went through the gearbox and chipped the teeth ( phew, that's one question solved).
I whipped front lower cover off .... and being very lazy hooked the massive 3/4" rattle gun to the lower nut and spun it off.
The top cover.
Checkout the number of shims behind the bottom front plate/bearing holder
Someone has been here before. The tabs that you bend back are damaged from previously being bent. I just gave each output shaft a couple of gentle taps with a rubber mallet and it pinion came away.
To my very unprofessional, incompetent eyes, this all looks extremely good, including the bearings. I won't pull it apart unless I find a good reason (if it all bolts back together within factory specs). I can already hear all boo'ing and hissing from people reading this
A quick look convinces ... damn, you can't just slide either of the shafts out. Things look pretty sad when you actually see me with a manual open beside what I"m trying to dismantle
Now if I'm reading the manual right, I need to strip the back off the top shaft. .... I hate snap rings and these bloody spring clips you can't grab with normal circlip pliers. I managed to work it off with 3 small screwdrivers without damage (I'm sure there is a special tool for these rings, but I don't own it!).
It's two seperate bearings, I found they will readily tap back through if gently tapped back through the housing. If the 2nd bearing stops dead, make sure the washer between them hasn't grabbed the circlip groove.
This clip readily slides down the slide as you can lift and pry it forward at the same time quite easily.
The gear the engages the reverse idler then slides down the shaft and off.
the manual seems to think I can move the top shaft down and to the side and it'll slide out forward. I reckon I'll need to remove the nut and bearing off the front of it first. I'll hopefully get outside later tonight and try this. That synchro hub will certianly need to come off first. And likely so will those big gears,, I can't see how they can fit through the gearbox housing.
The top cover.
