The pump came from a 405 SRDT which was running a bit smokey. Suspect a turbo oil leak or low compression since getting the injectors done didn't fix it.
$300
$300
Yes, still got it. It was a 1995 wagon with 300,000km on it. It was owned by a dealer mechanic in Bundaberg until about mid 2018, then some guy bought it and brought it to Brisbane and kept it for a year, sold it to me and I drove it for a year, then it sat in my garage for a year before I pulled the pump out.Hi Blufires, Have you still got the pump.?? Have you any idea as to how many k's on the 405 SRDT and what year it was.??
Thanks and all the best. Cheers sisu Paddy
I'm not sure when it was done but I'm pretty sure the pump has been rebuilt at some point. There's the telltale yellow paint marker on all the adjustment screws.Not putting you off but you will soon learn the curse of ULSD, the seals will leak, so replace the main front seal before it goes in.
Hey mate, still available by chance?The pump came from a 405 SRDT which was running a bit smokey. Suspect a turbo oil leak or low compression since getting the injectors done didn't fix it.
$300
