Anyone know if this has been done in Oz? By anyone?
several EU UK examples and kits too….
I regard it as truly disrespectful to the concept, the outcome, the vehicle and most importantly the man that built it.Hi.
That video clip has the most annoying commentators voice ever, very grating.
Could be worse, at least he's not conducting a funeral service.Hi.
Here you go, did take a bit of searching!He’s got a blog of the build somewhere but for reasons known only to google it can’t find it.
Do 900kms easy, if the battery's big enough.If there are kits for electrifying a DS, what about an XM?
If my 4HP20 transmission dies (again) I think I'd rather contribute the cost towards a more permanent solution (would also solve exhaust system problems once and for all).
But would I keep the 900+ km range?
I'd just set of up the standard pump with its own motor or replace it completely with an integral aftermarket electric hydraulic pump. An adaptor plate is pretty straight forward to make.Hardest part will be setting up the pump for the hydro etc and fabricating the gearbox adaptor plate
