EV conversion costs
Conversion costs are bit like 'how long is a piece of string'. Basic DC conversions with lead acid batteries run from $10K to a high-end DC one with Li batteries at nearly $30K. (Au dollars, parts only, plus donor car). A mid-range AC motor and controller with Li battery system would be about $35K, parts only, plus car. (You would not go lead acid for an AC motor). Highest end conversions using a Brusa combination motor and controller with the very best batteries on the market will give you little change out of $150k or more for just the parts!
And, yes, building an EV is ALWAYS more expensive than people expect – but I am a realist and give the actual figures whenever anyone asks. NB: If you want a blow-by-blow of a simple, but beautiful, DC EV conversion: you can’t go past this website: http://www.mightyboyev.com/
However, you can’t get around the fact that even the very simplest EV conversion will cost $10k in bits, if you're lucky and can make/do all the bits yourself, plus car. (Bits include: motor, controller, batteries, electrical cables, battery box, electrical system control components, adaptor plate = bell housing replacement to join motor and gearbox, direct coupling = clutch replacement for between motor & gearbox {more complex conversions actually retain the clutch}, motor mounts, demister replacement system, vacuum brake replacement system, DC/DC converter to replace the alternator, dash switches & lights, traction battery charging system, inlet plug, etc, etc, etc).
Below are a few websites for prices to flesh out the prices a bit:
http://www.evworks.com.au/index.php
http://www.evparts.com/
