ECU, BSI replacement options
Snooze
Red hill,vic
Hi All,
My Partner van is having it's ECU and BSI bench tested but....they can't test them 100%
I'm now considering installing a second-hand security set (ECU,BSI, & Keys)
Someone told that no re-programming will be required? True or False?
But someone else said the injectors will need to be programmed to the ECU? True or False?
Your thoughts will greatly appreciated,
Regards Snooze
No program required if off exactly same model of partner injectors will need coding but will run without it
4008
Gone but not forgotten C5 x7 3008 206 GTI 180 306 XR SED 405 MI16 x2 xzara VTS 406 SV 206 XT Berlingo 2011 (best car ever) 306 HDI 307 XSE HDI touring
Fix it right the first time
