Hi All,
Looking for some early hydraulic pump bolts fro the 7 piston pump for our 6H. They are not the same as later bolts. Ronald from Citrotech says he has never seen them before?
I only have 4:
Anyone who has a few, in an old collection of early DS bolts, I would love to buy them from you.
Best regards,
Greg
BTW, the 6H 7 piston pump, is almost identical to that used till the last of those pumps, that was used in the CX, apart from the location of the suction pipe, and that the pump outlet pipe is used as the pump mount as well (like early DS's), is that the 6H pump uses a brass bush at the back of the swash plate, and later pumps on the DS changed to a needle bearing.
Guess they got of lot of hydraulic parts right the first time. Greg
I only have 4:
Best regards,
Greg
