• Tapatalk and Mobile iOS/ Android APPs no longer supported on aussiefrogs.com. Please delete on your device. Use the web interface instead.
DS Boot light
Non of my cars have working boot light! in my 21 the light part is OK but nothing to turn it on. Should it have a gravity switch, or what, advise please.
Woody
The boot light switch is a very simple device about the diameter of a thin pencil that attaches to the moving part of the hinge. It has an internal steel ball that completes the circuit when tilted upwards..a gravity switch as you mention.
I suspect the ball and the contact point at the base are corroded...if there at all.
robmac
You could consider fitting one of these:
https://www.jaycar.com.au/spst-mercury-switch/p/SM1035
Totally sealed and rated to 36 watts.
I'd suggest it's likely to be more reliable than mechanical switches.
badabec
Hello, and if it does work, the light is about as much use as tits on a boar hog. I changed to a mercury switch and glued some flat LED panels to the parcel shelf.
If you know your films, it's like a scene from Repo Man when you open the boot.
PeterMol
Great idea!
steely
New member
Woody
Hi, i just wired up a boot switch in my DS23, utilized a gravity switch on the hinge, and an LED strip in the original style lense, looks the part, works, and has a very low current draw in case the switch sticks etc.
Ian
Dapco Auto France
