Purists look away!
Matthew
OK brains trust..a question. I was manoeuvring the car the other day and the bonnet cable on the left caught on the steering rack arm... pulling the cable out of the toggle?? at the bonnet catch end. Cable is ok but a tad frayed.
There re is a clamp on the front guard that secures the cable in its plastic sleeve, in place. In this position you can see where it passes above the steering joint.
This has never happened before. If I don't secure the cable in the clamp it passes higher above the steering arm. Does it have to be in the clamp? Anyone else had this experience?
Matthew
Hi Matthew,
Not had this happen in my experience. . .
I can see how your cable would be a problem as it is, it looks a little loose? Did you remove it to fit the front side carpet over the bonnet release? I would try putting a little more tension on the cable, and/or try turning the clamp 180 degrees to lift the cable a little? At worst use a cable tie loosely to secure the cable above the steering knuckle?
It's almost time to buy your second one, Matthew!
I take that back Chris... I rotated the clamp and it's ok now... lifted the cable to give plenty of clearance.
Matthew
I thought so Matthew but couldn't check on my car because those parts are not fitted - but 648 shows the clamp #23 is orientated such. . .
A few moments in the open air at dusk... 5 degrees here today! Interior complete, buff and polish done. Still to do but perhaps another time... the side strips, front valance, front bumper bar, B and C pillar trim.
Sitting in on the front seat was an experience... I almost didn't fit under the steering wheel! lol... it'll compress soon enough I guess. The camera on this iPhone is hopeless so sorry for the poor quality.
It's certainly come a long way since I took ownership... here's the original advertisement pic. I thought I was buying a brown car!
Matthew
Perfect day for an outing... perhaps I'll be a fair weather driver...
Matthew
