That's the usual starting point in my experience!If fuel doesn't stop flowing when the float is up the needle valve is no good. You can run Col's experiment again, but this time don't use a container under the carby cover. Just hold the carby cover in your hand with the gravity fed reservoir attached and push the float with your hand up gently to see if the fuel flow stops at some point. Try it a few times.
If you don't mind, you can try another way. Take the needle seat out and with the needle in, try sucking on the fuel inlet. You should be able to create enough vacuum that your tongue will stick to it and the needle won't fall out.
I'm intrigued if you found the problem or resorted to the box of matches.Ive got a 36DCD Weber on my R10 1300, which was running fine. I removed and re-fitted the cylinder head to fix a top end rattle and after re-fitting every thing, the car will not run. It fires up o.k. but will only run for a few seconds before flooding and cutting out. After all the usual checks, jet cleaning (with compressor), etc.
I need help, or a box of matches!
Henry
AFTER getting the insurance in order, of course.I'm intrigued if you found the problem or resorted to the box of matches.
Just get the insurance right before striking the match!!! Oh, and be careful just to burn the carbie, not the car....Alex, I have ordered a "repair kit" from ebay (which includes a new needle and seat) and still waiting for it to arrive. After fitting the new kit, I will keep all informed of results. Still keeping the matches handy!
Henry
So the key question here is: What has changed? Everything was running normally prior to the head work being performed. I know some of the following have been asked previously and some questions are a bit left field, but need to be asked anyway.Can someone please help me?
I tried it with the air filter removed and then noticed that the main jet discharge nozzle (was pumping out a lot of fuel while cranking and when running (1000 to 2000 rpm). This is causing the engine to emitt black smoke and then cut out. The needle /seat is almost new and no leaks in floats.
Acording to my limited knowlege and experience, I'm sure the main jet should not be operating at such low revs with no load. Whats even more puzzling is that I have tried 2 different carbs(after transfering the jets and choke tubes) and the still the problem persists! I have tried lowering the float level to 6mm in lieu of the specified 5mm, but the problem remains. I've stripped the carb and cleaned jets and fuel ways/air ways a half a dozen times....no luck.
This is a key observation. Need to determine where the fuel is going to.Schlits, if i leave fuel in the gravity "tank", it drains away into the carb and then who knows where! Must be going through carb to inlet manifold. There is no sign of fuel running down head/block, must be running into inlet then cylinder head. I tried another (used but good looking) needle and seat, but no difference.
One thing is for sure. It'll be very obvious in hindsight.....oooooh fuel bowl vent!
