Learning curve:
Today was the day to try out the polly wheels and the stud welder.
First stripped off the paint with a 100mm polly wheel which worked fine, took less than a minute to remove this much paint, so I think these were a good buy.
Next I welded some 2mm studs to the lowest part of the dent.
When I attached the slide hammer to the 2mm studs it did not grip to well and slid off the studs. So I removed them by cutting them off with side cutters and grinding off the stub left behind and then welded on some 3mm studs that the slide hammer gripped well on. Managed to remove most of the dent. The 3mm studs are actually easier to remove than the 2mm studs by getting the side cutters up close to the panel, leaving very little to grind off.
Paint removed using the purple polly wheel in a 100mm grinder
2mm studs welded tothe left sill.
3mm Studs welded to the left sill
Most of the dent removed.
How it is tonight, still a little more work required.
