I have a problem with my 505's clutch. After a decent trip (around 600kms of mostly the windiest roads in Australia) the next day it was difficult to put my car into gear, and change gears whilst moving. When stationary the car would move forward slightly as I put it into 1st or slightly backwards as I put the car into reverse.
Now this I suspected the clutch wasn't disengaging fully, so looking at both the master and slave cylinders and comparing my pedal travel/weight to another 505 my mechanic and myself came to the conclusion that the master cylinder was the cause of the problem, so we put a new one in today. After looking at the seals, some slight wear was noticed, but not enough to indicate that it was the culprit to the sudden change.
Also after we changed the master cylinders, the problem was lessened, but the clutch still isn't fully disengaging.
Now the clutch isn't slipping at all, so it may not be a worn clutch. If it was the gearbox and syncro's failing then I shouldn't notice the car moving slighty when I change gears at idle.
Has anyone come across the same problem and know what it is? I really don't want to change the clutch, as that's going to be a nightmare, and find that didn't solve the problem.
Also has anyone changed a clutch in a 505, and if so what's the best way to get at it? Due to the driveshaft being solidly bolted to the diff and the engine, it's not a simple matter of dropping the tailshaft and sliding the gearbox back, as it was in the Celica I used to drive.
Thanks in advance for the assistance.
