Following on from my other thread http://www.aussiefrogs.com/forum/renault-forum/105578-when-too-far-gone-bother-fixing.html
I have decided to try and fix the body, after all I've already done the engine and gearbox. What's the worst that could happen, I can't make it any worse.
Now this is the first time I've ever welded metal this thin, and it is really thin. My MIG only goes down to 15.5A and I think I'd like it to go down a little further. After playing around with the wire speed I got it to a point of not blowing too many holes in the car. I'm also using 1mm zincanneal, which is a little thicker then what the car is made out of.
So to begin, I started on the passenger side rear, I figured I'd start with an easy one.... Step one, work out the shape of the piece to replace using cardboard, then cut out the infected area, then discover a little more to cut out. Luckily the bit down the side is flat so no template is needed. I drilled out the spot welds so I could remove the bent over strip at the bottom. You can tell it was spot welded by hand, they are not exactly in a straight line or evenly spaced.
The first patch to make is the bottom of the rear window, its actually curved in two directions, I put a curve in it longways and welded one end down then I heated it up and persuaded it into place as I tacked the rest of it down. I reasonably happy with the result as this is the first time I've done this, and you won't be able to see this one.
