3006828 has first dibs, but if you are missing something have a look within my boxes and if there is anything you need, happy to pass on.
Door lock trim, ashtrays, window winders
https://photos.app.goo.gl/8Kob6JRShsP1LMdAA
Door locks, handles, strikers, other plastic bits, a few (should be at least 1 x set of door latches also)
https://photos.app.goo.gl/TrnaUShcp2wPdi6R6
Virage front arm rests, rear arm rests, those mirrors that need the mounting plate which I don't have,
https://photos.app.goo.gl/3S4g3xnx5SfbsncV6
Virage front seats. Passenger is mint, drivers has had stitching fail as shown
https://photos.app.goo.gl/qAenumoJHqMapABc8
https://photos.app.goo.gl/GCogBv1avGQpFW6Z6
Brown Virage door trim. Will need to touch up, but sometimes trim is better then not.
https://photos.app.goo.gl/rDk7bdrHRN8zf5yf7
Doggo in the window, not for free, although will bark at you should you arrive to pick stuff up.
https://photos.app.goo.gl/ZYVz6wUQoqbLdMSX8
Chrome and other shiny bits, door frame trim set, and other random sections salvaged. There is at least 1 x bonnet piece, 3 x bottom under the door trim pieces, those later rubber'd ones no idea, assuming from the Virage, chrome from window rubbers, and I think 3 x pieces that where from the weather rail along the roof.
https://photos.app.goo.gl/39rRKdoFQNhxF2Fi8
https://photos.app.goo.gl/18kGYhMzhbMRxm1Y6
Oh there are certainly some window mechanisms if you need, I should have at least a set here somewhere. And, 1 x rear seat base (brown with black sides)
Not wanting to become rich, happy to have these bits used if any of you need any of them for your projects.
I'd probably ask for a bottle of wine for seats however, I've been really enjoying cheap Tempranillo's from Spain / Argentina! You should check it out if you like the flavour of Siraz without that weight that sometimes has you feeling if you should be reading sad poetry.
