Big 6 front wheel drum
robo
Active member
Hi, can someone tell me how to remove the front wheel brake drums off a Traction Avant 6 Cylinder?
Mark
There are two access holes in the front of the drum. A tube spanner ( 12mm IFRC ) is used to undo the the six set screws holding the bearing retaining plate The stub axle nut must be removed and the drive shaft removed. Then the drum and bearing will slide out of the steering swivel assembly revealing the the brake shoes and wheel cylinders.
Yes Mark:
Assuming it is similar to the light 15 I made a tool for same, pictured here:
Bought from Trade Tools for about $30 & carefully modify the jaws to fit tightly on the hub groove.
Load up on the axle very tightly then shock to the tool bolt head with a club/lump/gympie hammer.
Set up right the hub should pop off if you loosened off the brake adjusters.
I no longer need, but have this tool, as I fitted power disc brakes.
Thanks Gerry, I think I’ve got it now, I thought the 2 holes must have something to do with it.
Mark
Yes Mark:
View attachment 126760View attachment 126761View attachment 126762
No it’s different there’s nowhere for a puller to grab.
Mark
Thanks Gerry for helping Mark. I could not remember exactly. The last time I did that to my Big 6 was in the early 80's. But it is time to re-do my brakes too. It is a timely reminder. Ted
I sold my 6H to Kim Harding in the late seventies and I remember those details clearly Ted!
Got them off this 1/2 inch socket extension is a perfect mandrel.
The right bearing is shot left ok but I guess I should change both mot cheep at $500 a pop
The right bearing is shot left ok but I guess I should change both mot cheep at $500 a pop View attachment 126895View attachment 126896
Looks like someone else has a vast collection of broken and bent socket extension bars ..... I haven't many usable ones left. What are driving out with the bar? That looks very different to the light 15.
Yes very different to a light 15 you have to
That looks very different to the light 15 you have to remove the driveshaft put a mandrel in “or 1/2inch socket extension” in and knock the hub off bearing and all. Can’t think it’s good for the bearings.
Driving out the hub and bearing. Bearing is pressed onto the hub ( integral with the brake drum )in the same manner as a GS bearing.
