When installing electrical accessories (lights, winches, etc.) on newer vehicles, be careful not to make electrical connections so close to the battery terminals that you inadvertently bypass a Battery Current Sensor. The computer increases or decreases alternator output based on the amount of electrical current it sees being drawn through the Battery Current Sensor. When new electrical connections are made directly to the battery terminals, the current going to the new accessory is unseen by the computer, alternator output is kept low and the battery eventually goes dead.
See the Battery Current Sensor for your specific vehicle under "Electrical" in the RockAuto.com catalog. The repair manual (found under "Literature) or owners manual can also help determine if your vehicle's Battery Current Sensor is on the positive or negative side. Battery current sensors are most commonly part of the negative battery cable circuit. On those vehicles, grounding a new electrical accessory to the body or engine block rather than directly to the negative battery terminal is all it takes to avoid bypassing the Battery Current Sensor.
The computer and its Battery Current Sensor also change how to use a multimeter to check alternator output. To maximize fuel economy, the computer may use the Battery Current Sensor signal to keep alternator output as low as possible. That means a multimeter's probes placed on the battery terminals may show less than 13 volts when the engine is idling. That low voltage does not mean the alternator is bad. It may just mean the computer has not increased alternator output because there is not enough current going through the Battery Current Sensor. Turn on the headlights, rear window defroster or some other significant electrical load. The computer will respond by increasing alternator output, and the multimeter will read ~14 volts at the battery terminals.
Tom Taylor,
RockAuto.com
