Another Shed Clearout
pgti6
Well-known member
* XU10J4 cast iron engine mount which bolts to the iron block including the connecting piece across to the body engine mount. Comes with all bolts. $75.
***Connecting mount from engine to body. SOLD. Mount to block (with bolts) still available. $35
* XU9J4 modified breather/catch can system for quad throttle bodies using Baker BM hoses to head and block, mounts to bell housing. $100.
* Various AN12 & AN10 fittings for braided hose. Brand new. Approx 10 in total. $125 lot.
* Earle's inline oil filter AN10. $40.
* Peterson remote oil pressure valve AN10. Trial fitted but never used. $150.
* 0830 28 Cambelt tensioner pulley. SKF brand. Suit M59 Partner van. New $25.
* Shift light 2 led green/red. $35.
* Motec round multi led shift light $50.
More items added-
*XU10J4RS Top Radiator Hose $40.
* Grayston 60mm studs x 8, suit Pug/Cit FWD cars $20.
* Grayston flat face wheel nuts x 16. $32.
* Pug/Cit black tapered wheel bolts $1.00 each
More items added 29th Aug
* Bottom radiator hose (suit J4R/RS) and distribution 2 hose housing suit J4R Check for compatibility $40.
** Pics further down the page.
Located in Box Hill.
Will post smaller items otherwise local pick up.
Hell mate, interested in the catch can system. Can you send me some pics please.
Thanks.
Hi Jeff ill take all the long and short chrome wheel bolts if still there 20 in total. Ill send a pm
More items discovered and added-
* Oil catch can filter $15
* XU10 Engine block mount $35
* XU10J4R & J4RS Crank angle sensor $35
Sorry Geoff xu10j4rs crank angle sensor, good buy either way! Good for a j4r and many others1
Thanks Matt. I had a feeing after posting they were blue!
Yep still here. Get in quick. Skip coming in 7 days.
* GTi6 Inlet Manifold complete with throttle body, fuel rail (green) injectors & sensors. $300.
* GTi6 stainless steel extractors back 2 1/2” exhaust system. High flow cat, centre resonator and rear muffler. Best suited for a tuned engine. $250.
* 2 x 405 Series 1 plastic dash pieces at the bottom of the windscreen. Free. GONE.
* 1 x XU10J4R cyl head. Removed from an 2 litre auto at Imlach’s. Complete with coils (they are different to GTi6 ones). Same valve sizes as an Mi16 head. $80.
* XU9J4 alloy block $50.
* XU9J4 4-1 custom exhaust manifold (9 bolt) for 405. Heat treated. $125. SOLD
* XU9J4 throttle body. $20.
* 406 283mm calipers. Also a good upgrade as it fits a 405. $75 pair.
* XU10 block with oil sprays. $75.
* Mi16 & 205 gearboxes (3ish in total) $100 the lot.
* 4 x Bosch xxx xxx 762 fuel injectors suit 1.9 Mi16 and (I think) 8v as well. $50. SOLD.
* 1 x 215mm flywheel, 1 standard. Suit 1.9 & 2.0 litre Mi16, GTi6 $40. SOLD.
* Autometer 2" 0-100 psi oil pressure gauge including copper & nylon lines, fittings, olives, etc. $100. SOLD.
* 08290 20 Cambelt tensioner pulley. SKF brand. Suit 306 2 litre, 309, 405. New $25. SOLD.
* 405 series 1 K frame, lower control arms and hubs, (bushes and bearings replaced not long ago). PRICE REDUCTION $80.
* 405 Mi16 P/steering belt (for gearbox mounted pump). New $20.
* XU9J4 Camtech Performance Cams (2) for use with standard hydraulic lifters. SOLD.
Adv Duration-272°
Lift @ 0.050”-236°
Cam Lift-0.448”
Lift @ Valve-11.38mm
Lift @ TDC-0.111” (2.82mm)
Intake Centreline 106°
Lobe separation angle 108°
$400
Added items-
* XU10 Windage tray & the 4 special main bearing bolts which it attaches by. $75. SOLD
More items added-
*XU10J4R Cam Gears. May suit J4RS (GTi6/VTS) as well. $70 pair.
I'm sorry mate - I don't get on here any more. If you still have them, let me know how much and I'll get you to post them.
Thanks.
