Good to see your result.
Please give us a 6 month update.
Have you only done the one change? I'm pretty sure that the AL4, like other autos, hangs onto at least half of it's fluid when you drain it, so all you've done so far is to dilute the old fluid. A couple more changes (maybe allow 1000 km between changes) and you should have got rid of most of the old fluid, which may help.
If you get more thumps in hotter weather, when the engine has been at operating temp for a while, you may need to look at improving the transmission cooling. I have a 4HP20 coupled to an ES9J4 engine, and the transmission "cooler" is actually a heat exchanger which transfers heat from the engine (via the coolant) into the transmission fluid, so the transmission is forced to run at engine temperature. If the AL4 uses the same system, then getting rid of the heat exchanger and installing a separate transmission cooler will help the transmission to run cooler, extending it's life and stopping the thumps.
My mechanic has recommended a fluid change in my 2005 C5 HDI every second service, he doesn't believe in sealed for life either.Hey Stew ....I think crap is a bit harsh ...personally I think any auto on anything other than a nice tourquey Vs is crap. .... and Europeans have never done Autos well ... especially 4 cylinder autos! In my experience with both the 4speed SF box that preceded this one in the BX and 405 and the AL4 it was poor or infrequent servicing and / or ignorance regarding the importance of the correct fluid as we'll as our heat that combined to kill them early ....the concept of sealed for life doesn't help! As for an update on our AL4.... after 600klms still shifting nicely.... and if all it will need is a tube of friction modifier every so often to keep it that way ...happy days!
Never had any problem with ZF.s in 504 and 505 s.Whoever built the AL4 destroyed a great Company.Hey Stew ....I think crap is a bit harsh ...personally I think any auto on anything other than a nice tourquey Vs is crap. .... and Europeans have never done Autos well ... especially 4 cylinder autos! In my experience with both the 4speed SF box that preceded this one in the BX and 405 and the AL4 it was poor or infrequent servicing and / or ignorance regarding the importance of the correct fluid as we'll as our heat that combined to kill them early ....the concept of sealed for life doesn't help! As for an update on our AL4.... after 600klms still shifting nicely.... and if all it will need is a tube of friction modifier every so often to keep it that way ...happy days!
