RIP AUSSIEFROGS
nevertheless, work continues. i've replaced all the fuel lines to the injector
done the oil change, curse the tiny hands of whoever decided to put the oil filter here
you vs the guy she tells you not to worry about
was all gung ho and ready to drain the gearbox, and try to replace the broken cv boot with one i harvested from the box of mystery cv shafts in the backyard
very well lubricated shafts these are
hopefully one of these will fit, but my 8mm square drive bit is just a lil too girthy to fit in the drain plug hole
hopefully i can find the bit of 8mm square bar i have lying around here somewhere, and get this gearbox freshened up a lil.
but on to the real headache>
snapping that brake bleeder valve off in the caliper has cause such a headache, from literally none of the 6-7 parts stores i've gone to stocking or even being able to order in spare bleeder valves, to the struggle of getting the old bleeder out of the bolt hole. spent $17 on an extractor bit that snapped off in the hole literally as soon as it grabbed.
the brakes aren't in the best of condition anyway, so i've decided simply replacing or upgrading them is likely the best option, so I ask ye gurus of aussiefrogs, how hard is it to fit 306 or 206 brakes? has anyone done it before, are there perhaps any build threads or how to's? any and all advice would be much appreciated.
also got to help smash a couch to take it to the tip cause it wouldn't fit in anyones car otherwise, that was fun.
